Straight Pipe (cat. converter) O2 sensor
![Question](https://www.vadriven.com/forums/images/icons/icon5.gif)
Have a question. I just installed a straight pipe and took out the cat. converter. So now there is no O2 sensor hole in it, so what should I do? Can I get a hole made in the straight pipe? Does not using the O2 sensor make car run crappy as far as not buring right? I tape the sensor up for now, and still do not have a check engine light, so hopefully thats good thing. 99 Civic EX Thanks for you help.
![IC x Prince](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![IC x Prince](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
Originally posted by QUIK4A4
Have a question. I just installed a straight pipe and took out the cat. converter. So now there is no O2 sensor hole in it, so what should I do? Can I get a hole made in the straight pipe? Does not using the O2 sensor make car run crappy as far as not buring right? I tape the sensor up for now, and still do not have a check engine light, so hopefully thats good thing. Thanks for you help.
JDM_EF-9
Want to Buy / Trade ARCHIVE
07-14-2008 06:48 PM
