Stripped lugnut!!HELP
Old 08-31-2007, 07:05 PM
vdubya63's Avatar
vdubya63 has disabled reputation
Default Stripped lugnut!!HELP
Whats up guys well I got a flat the other day and went to remove all the lugs and got to the last one and the damn thing was so tight on there that I ended up being a dumbass and stripped it really bad.. It was a 21mm now I can geta 20 mm on there easily what should i do? I went to the store to get oneof those sockets for the stripped bolts but all they went up to was 19mm.. So I tried just cutting a little notchin the lug and stuck a screwdriver in there and beat it with a hammer mopeing it would come loose but no luck..Should i just take it to a wheel shop? or do you all have any secret methods..thanks in advance for any help
vdubya63 is offline
Old 08-31-2007, 07:18 PM
やくざに成りたい
atmdc's Avatar
atmdc has disabled reputation
Default Re: Stripped lugnut!!HELP
hammer on a smaller socket and impact it off, then replace
atmdc is offline
Bitches get Stitches
sk8rmike's Avatar
air hammer w/ chisel accessory ftw. you can also burn them off with an acetelyne torch but you sometimes damage the rim that way. if you have access to a welder, you could try to weld a nut on and turn it off with that. if you dont have access to any of that, i guess you could use a hammer and chisel and try to notch into the lugnut and hit it the way you need to to turn it off.
sk8rmike is offline
Old 08-31-2007, 08:37 PM
a11m0trwh0r3's Avatar
a11m0trwh0r3 is an unknown quantity at this point
a11m0trwh0r3 is offline
Old 09-01-2007, 04:44 AM
CamboEF9's Avatar
CamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these partsCamboEF9 is infamous around these parts
how about a gator grip socket?
CamboEF9 is offline
Old 09-01-2007, 07:34 AM
Justa lil 6
Dang Yo's Avatar
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
better start drilling.
Dang Yo is offline
Old 09-01-2007, 01:36 PM
sk8rmike's Avatar
those things are fuckin worthless...if you have one just junk it.
sk8rmike is offline
Old 09-01-2007, 01:58 PM
nyteshade151's Avatar
nyteshade151 has disabled reputation
wow all you have to do is get a pair of vice grips clamp it down on the socket so it's tight take a rubber mallet or small hammer and hit it in the direction to loosen it........after it loosens some you should be able to just turn it socket...
nyteshade151 is offline
Old 09-01-2007, 04:07 PM
ouji's Avatar
ouji can only hope to improve
torch it.
ouji is offline
Old 09-01-2007, 04:40 PM
.eric.'s Avatar
.eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric. .eric.
If you can get a 20mm on there easily, then get yourself a 12 point 19mm socket and hammer it onto the lugnut. Then take a socket wrench and remove it. I used this method many times before...
.eric. is offline
Quick Reply: Stripped lugnut!!HELP
