TPS CALIBRATION PROBLEM
#21
Re: TPS CALIBRATION PROBLEM
Actually was just using ground off battery but asked someone and they said to use screw thats holding TPS in TB and it was same reading But C16EFSEDAN has a good point im going to check out today
#22
It's very important to do things the proper way while trying to troubleshoot problems like this; if you're having problems getting the voltage in the right range then you might have just found out why the ECU is having problems reading that sensor properly...
#23
Im just going to have someone look at it for me because when I did it off just wires yesterday CLOSED TB was in the 3.0V's and 4.0V's so wiring is most likely DOO DOO but I started it this morning and after cranking it forever, for it to start and stay running it finally did and when the temp started getting warmer car was acting more like a honda and i drove it up road spinning thru 1st and 2nd soooo its a STUPID problem lol
#25
What i mean is that that screw will act like your partially on the throttle if its adjusted out to far. Essentially not letting the throttle body close completely when sitting idle.
#27
#28
Dont know which one it could be theres 3 and didnt think that would mess the running up...im going to test fuel pressure this morning to see if anythings wrong in that department
#29
Stop being stubborn. I'm not telling you to fix things that are completely unrelated to the problems you're having, I'm telling you to fix things that will help solve your problems.
You can check fuel pressure and whatever else you feel like checking, but until you get the known problems figured out (the TPS and the ECT) then you're just wasting your time doing anything else.
#30
well checked fuel pressure and its low, TPS isnt throwing code no more just ECT and fuel pressure at turn key wont go past 34psi no matter how many times I turn key....idling its at 28psi and WOT it jumps to 34psi...... so low fuel pressure and ECT pretty much got it figured out I guess
THANKS GUYS will post if I still have problems
