tranny popping out in 5th
Re: tranny popping out in 5th
Actually...if the 5th gear shift fork is worn, then the ring gear will not fully engage the the 5th gear syncro as to cause the dreaded "popping out of gear" syndrome.
Now if the problem was grinding of several/all gears or popping out of several gears then the problem would be related to the items that all gears would share...ie, linkage, or shifting interlock.
The 5th gear shift fork wear is common in poorly maintained Honda MT
