trans help...
Old 03-06-2014, 04:57 AM
buck50shot's Avatar
buck50shot has disabled reputation
Default trans help...
I have a 93 eg coupe auto that trans went out but I have a 97 auto trans. Didn't knOw if it would work because of different years one obd1 the other obd2.. wanted to know if if would work before I swapped them....
buck50shot is offline
Old 03-06-2014, 05:35 AM
Default Re: trans help...
I don't think that will work without swapping some other things as well. I'm no auto trans expert but I believe the OBD2 ECU controls the trans itself, while the OBD1 ECU has a separate TCM? I might be thinking of the B-series stuff though (I've never had an urge to learn about D-series), and there are control differences between the D-series trans than the B-series trans so I could be steering you wrong. I'd start doing some research because I don't think this is a straightforward thing to do. You might be better off getting another OBD1 trans and using that.
Old 03-06-2014, 05:23 PM
ej1995's Avatar
ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995
http://www.d-series.org/forums/engin...-possible.html
ej1995 is offline
WiFi KiD79
10-19-2009 10:00 AM
i need a civic!
03-22-2009 08:40 PM
skr00zloose
03-24-2006 09:35 PM
u blinkd
02-03-2006 01:57 PM
4g63NT
02-15-2004 06:48 PM
Quick Reply: trans help...
