Trouble with ls vtec swap
Old 10-19-2009, 05:38 PM
efsedan's Avatar
efsedan has disabled reputation
Default close.......
got problem fixed
efsedan is offline
Old 10-20-2009, 04:48 PM
92gsrteg's Avatar
92gsrteg has disabled reputation
Default Re: Trouble with ls vtec swap
some body help im in the same process. i need to know what all mounts to use. espacially with the rear mount
92gsrteg is offline
Old 10-20-2009, 06:13 PM
The Douche is here
oodie's Avatar
oodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these partsoodie is infamous around these parts
Which mounts are you using the eg civic and integras use the 3 bolt mount.
oodie is offline
Old 10-20-2009, 06:19 PM
boostedb16's Avatar
boostedb16 has disabled reputation
timing belt mount- u need both pieces off 94+ integra also ac bracket off 94+ integra also tranny side torque mount off 94+ integra top tranny mount is the same on integra and civic five speed and u will need the back T or also called L bracket off 94+ integra
boostedb16 is offline
Old 10-20-2009, 08:31 PM
kadafiz's Avatar
kadafiz has disabled reputation
Im pretty sure the driver side mount is the same on eg civic's and dc integra's.. The tranny mount is different
kadafiz is offline
tonessi
02-05-2009 11:18 AM
one pnt 8 hatch
03-12-2005 04:05 AM
white crx si
02-27-2005 07:52 AM
bustedhatch88
11-20-2003 07:04 PM
Quick Reply: Trouble with ls vtec swap
