turbo 94 civic wont start
![civicfreak1985 has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
i had a d16z6 motor built with eagle rods and wiseco pistons bored the block 20 over when i got the motor back from the shop i put it in the car an slaped all the turbo stuff on with that i put 450 dsm injectors on with a resister boxwent to go start the car an it didnt start up
are you using something to tune those big injectors or did i miss that. i surely hope you dont think you can just put big injectors in a car that uses 240cc injectors and expect it to crank
are you getting spark? take a plug and put it in a plug wire and ground it to the motor and see if it sparks while turning the car over. if you do not have spark, check the power plugs of the distributor with the key in acc and see if you have power to any of the wires
