turbo 94 civic wont start
Old 01-21-2010, 03:20 PM
civicfreak1985's Avatar
civicfreak1985 has disabled reputation
Default Re: turbo 94 civic wont start
a company called speed pro inavations in florida but i will go crome after i get my car started cause i hooked up the stock injectors,ecu an took the resister box off but it still wont start. yea im getting spark and fuel
civicfreak1985 is offline
Old 01-21-2010, 03:25 PM
#Trendy
Audio's Avatar
Audio Audio Audio Audio Audio Audio Audio Audio Audio Audio Audio
turn the key?
Audio is offline
Old 01-21-2010, 03:38 PM
If you have spark, and have fuel, you need to check the obvious stuff like plug wires in the wrong order, distributor backwards, etc. Also check continuity between the mating face of the distributor plug and the ECU. Also, try a different ECU. If you just got the ECU and the car isn't starting, don't trust that the ECU will run a car. You haven't seen it run a car, so it may not.
Old 01-22-2010, 06:01 PM
backtoarms's Avatar
backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms
Timing?
backtoarms is offline
2kCivic_GSR
10-21-2009 10:58 PM
Tiffany Sisino
07-02-2009 04:35 PM
pimpingreen13
12-29-2007 08:17 PM
REDHONDA
08-08-2006 12:20 PM
200+hp240sx
04-26-2005 05:32 PM
Quick Reply: turbo 94 civic wont start
