turbo car blue smoke at stop light
#22
Re: turbo car blue smoke at stop light
Run a .065 restrictor and see if that helps. Ive seen cases on HT similar to your situation with your set-up and that has resolved smoking.
#25
#26
ight well i just ordered it so we shall see how it works.....the only thing i could think abaout is that it never did it before so why is it doing it now?
#27
Eh, I assume it could be numerous things. Your feed line could of been clogged at one point and starved your turbo and messed up your seals. Bleh bleh who knows...Drain the system and check your lines for kinks, leaks, debris, etc. If clear run the ATP restrictor and update here.
I believe if the problem persist from there it may be the motor. Giving advice to fix the lesser of two evils first is the best I can do.
