VA State Inspection Question
Re: VA State Inspection Question
I took a look at a few clutch pedal assemblies from the 96-2000 Civics. It looks different than I'm used to. I believe the switch you want to reconnect is the yellow one seen in the picture on the left pedal.
superuser
driving into the bay is an insurance thing.
scraping off the sticker is a procedure thing for the inspection.
when you drive the car into a bay, you haven't started an inspection -- so no need to scrape off the sticker before you drive it into the shop, only when you begin an inspection.
+RepCarebearCrew
The state inspector is supposed to drive it in, that way he can check other things pulling in.
REQUIRED OFFICIAL INSPECTION PROCEDURE
Each inspection consists of the following items – for further details consult the "Official Inspection Manual":
1. - REMOVE OLD INSPECTION STICKER.
2. - DRIVE VEHICLE INTO INSPECTION LANE.
3. - INSPECT BRAKES FOR:
•Worn, damaged or missing parts.
•Worn, contaminated or defective linings or drums.
•Leaks in system, proper fluid level.
•Worn, contaminated or defective disc pads or discs.
(NOTE: A minimum of two wheels and drums must be removed from each vehicle at the time of inspection. Consult the official inspection manual for exceptions.)
4. - INSPECT PARKING BRAKE FOR:
•Broken or missing parts.
•Proper adjustment.
•Standard factory equipment or equivalent.
5. - INSPECT HEADLIGHTS FOR:
•Approved type, aim, and output.
•Condition of lamp, wiring and switch.
•Beam indicator.
6. - INSPECT OTHER LIGHTS FOR:
•Approved type, proper bulbs, condition of lenses, wiring and switch.
•Aim of fog and driving lamps.
•Illumination of all lamps, lens color, and condition of lens.
(NOTE: Every vehicle must have a rear lamp showing a red light to the rear, a white light illuminating the rear license plate; vehicles over 7 feet wide or extending 4 inches or more beyond the front fender extremes must be equipped with approved clearance lamps and reflex reflectors. Count load in measuring.)
7. – INSPECT SIGNAL DEVICE FOR:
•Correct indications and tell-tale (visual or audible).
8. – INSPECT STEERING & SUSPENSION FOR: (Jack up front end as shown in Manual)
•Wear in bushings, kingpins, ball joints, wheel bearings, tie rod ends.
•Looseness of gear box on frame, condition of drag link and steering arm.
•Play in steering wheel.
•Wheel alignment and axle alignment.
•Broken spring leaves, and worn shackles.
•Shock absorbers.
•Broken frame.
•Broken or missing engine mounts.
•Lift blocks.
9. – INSPECT TIRES, WHEELS & RIMS FOR:
•Condition of tires including tread depth.
•Mixing radials and bias ply tires.
•Wheels that are cracked or damaged so as to affect safe operation.
10. – INSPECT MIRROR FOR:
•Rigidity of mounting.
•Condition of reflecting surface.
•View of road to rear (Truck mirrors must extend at least halfway beyond edge of body) – (Visibility 200 feet to rear).
11. – INSPECT HORN FOR:
•Electrical connections, mounting and horn button.
•Emits sound audible for a minimum of 200 feet.
12. – INSPECT WINDSHIELD AND OTHER GLASS FOR:
•Approved type safety glass.
•Cloudiness, distortion or other obstruction to vision.
•Cracked, scratched or broken glass.
•Stickers. ALL UNAUTHORIZED STICKERS MUST BE REMOVED.
•Sunshading material attached to the windshield to ensure it does not extend more than 3 inches downward from the top of windshield, unless authorized by Medical Waiver Certificate.
•Operation of left front door glass.
13. – INSPECT WINDSHIELD WIPER/DEFROSTER FOR:
•Operating condition.
•Condition of blade.
14. – INSPECT EXHAUST SYSTEM FOR:
•Exhaust line-manifold, gaskets, pipes, mufflers, connections, etc.
•Leakage of gases at any point from motor to point discharged from system.
15. – INSPECT LICENSE TAGS FOR:
•Illumination of rear plate.
16. – INSPECT HOOD AND AREA UNDER THE HOOD FOR:
•Operating condition of hood latch.
•Presence of emissions system -Evidence that any essential parts have been removed, rendered inoperative or disconnected.
•Fluid levels that are below the proper level
1. Brake fluid.
2. Power steering fluid.
•Power steering belt - proper tension, wear, or absence.
17. – INSPECT AIR POLLUTION CONTROL SYSTEM (1973 and Subsequent Models) FOR:
•Installation.
•Operation.
(NOTE: This includes the catalytic converter and the fuel tank filler pipe.)
18. – INSPECT DRIVER’S SEAT FOR:
•Anchorage.
•Location.
•Condition.
19. – INSPECT SEAT BELTS FOR:
•Approved type.
•Installation.
20. – INSPECT AIR BAG AND AIRBAG READINESS LIGHT FOR:
•Any defects in the air bag system noted by the air bag readiness light, or otherwise indicated; or
•The air bag has been deployed and has not been replaced (and is not deactivated because of a medical or other exemption and a notice is posted to indicate that it has been deactivated); or
•Any part of the air bag system has been removed from the vehicle; or
•If the air bag indicator fails to light, or stays on continuously.
21. – INSPECT DOORS AT THE RIGHT & LEFT SIDE OF THE DRIVER’S SEAT FOR:
•Handle or opening device which will permit the opening of the door from the outside and inside of the vehicle.
•Latching system which will hold door in its proper closed position.
22. – INSPECT FUEL SYSTEM FOR:
•Any part that is not securely fastened.
•Liquid fuel leakage.
•Fuel tank filler cap for presence.
23. – INSPECT FLOOR PAN FOR:
(a) Holes which allow exhaust gases to enter occupant compartment.
(b) Conditions which create a hazard to the occupants.
24. – ISSUE STICKER:
(a) If approved, place approval sticker on the vehicle, and give pink copy of certificate to operator.
(b) ALL DEFECTS MUST BE CORRECTED AND THE VEHICLE REINSPECTED WITHIN 15 DAYS.
THE DRIVER MAY BE IN JEOPARDY OF RECEIVING A SUMMONS FOR ANY DEFECT STILL
PRESENT ANY TIME THE VEHICLE IS OPERATED ON THE HIGHWAY.
(NOTE: The validity period of the rejection sticker shall include fifteen (15) days in addition to the day of the inspection.)
•Proper adjustment.
•Beam indicator.
•Shock absorbers.
•Broken frame.
•Lift blocks.
1. Brake fluid.
•Installation.
•Operation.
•Anchorage.
•Location.
•Condition.
•Approved type.
•Installation.
After removing the inspection sticker, the safety inspector who is to perform the inspection must drive the vehicle into the inspection lane unless the safety inspector is not qualified to operate the vehicle.
During the operation of the vehicle, the safety inspector must make application of the service and parking brakes and check for conditions as set forth in Brake Sections of the inspection manual applicable to the vehicle being inspected.
superuser
looks like you are correct!
http://lis.virginia.gov/cgi-bin/legp...+19VAC30-70-20
the inspection begins when pulling into the service lane to check for brakes.
however, inspectors have always asked me to pull my car in and scrape off (and apply) the sticker myself under their supervision for shop liability reasons with my little red car.
superuser
Qualified is subjective. Techs don't feel "qualified" to drive my little red car, so they don't. I am also the one in the vehicle performing the instructed commands (lights on, etc) for them. There are only 3 people who have ever driven that car, ever.
Wow, I think that needs updating. That might have been relevent in the mid- to late-1960s...
Uno Mas
Based on the codes that were just posted, I didn't see anything relevant to the CPPS. I pick up the car today so I will see if the connector was simply unplugged. Not a huge deal either way, but the principle of that not qualifying as one of the things to fail a vehicle.
