vafc issue
vafc issue
ok so i hooked my vafc up today n after we worked some kinks out we got the car to run right. Well i drove around for awhile 3 hours and it was fine and then as i was getting on the interstate i accelerated and the car threw a check engine light and would no longer accelerate after 5k and it was shuddering and popping real bad what would cause this ?? i returned the setting back to normal and its still doing the same thing. i cant check the light tonight but any idea what could cause this??
Re: vafc issue
damn i meant for it to go in tech talk shit.
but i dont have a 4g63 nemore i have a 99 civic ex c
can i get a mod to move it im tired and frustrated and just clicked the wrong section sorry for the troubles though.
Re: vafc issue
Which generation VAFC is this? Are you running the AFC "hack", meaning... are you turboed? If not, do the easiest way out first.
1. "initialize" it to go back on default.
2. check make sure you are on "4-up arrow"
3. select "6 in, 6 out"
Also, what size injectors are you using?
Re: vafc issue
