Vtec head + Vtec lockers = LS head *read
Old 01-21-2010, 11:41 AM
VAdriven Sponsor
RameyBuilt's Avatar
RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt RameyBuilt
Default Re: Vtec head + Vtec lockers = LS head *read
all this is irrelevant cause a ls head is not going to flow enought cfm to use a cam that big, u would be taking steps backwards, in the end it comes down to how much power u want to make and really that is gona be limited on what the head is going to flow no matter how big the cam is, and a ls head just does not flow what a vtec head does no matter what u do to it, and the rocker arm design is completly different
RameyBuilt is offline
Old 01-21-2010, 11:43 AM
Drives a "black" dc2
Big Boosta's Avatar
Big Boosta Big Boosta Big Boosta Big Boosta Big Boosta Big Boosta Big Boosta Big Boosta Big Boosta Big Boosta Big Boosta
Originally Posted by theneonorder
Now i know there are 2 major downfalls to this,
1. The LS cam cap doesn't allow for a big lobe
2. The LS head just doesn't have the meat and design to allow flow like a vtec head.
But really, im just looking for a confirmation in concept.
Yeah, like i said not saying it would make more power, just the whole proof of concept.
Big Boosta is offline
Old 01-21-2010, 12:34 PM
braap braap
Jarrod's Avatar
and the rocker arm design is completly sucks
fixed.
Seriously. It got old having to take the valve cover off to make sure the little assholes didn't pop out.
The best cam/head setup for a LS is a P8R head with some Crower 404s or 405s for a nonstreeted car.
Jarrod is offline
Old 01-21-2010, 01:11 PM
Yes I race a HONDA!!
vbspec's Avatar
vbspec vbspec vbspec vbspec vbspec vbspec vbspec vbspec vbspec vbspec vbspec
It seems that you are asking that if you use a vtec killer cam in a vtec head will it work on just one specific cam lobe. Thus making like an ls head. In that case the "consept" is the same. Not much thought should have to go into that. It dose not mean that by throwing an crazy amount of money into an ls that you will get anywhere close to the results with the same investment in a vtec engine.
vbspec is offline
Old 01-21-2010, 03:31 PM
See what happens when I'm at work? Someone takes over and says what I would say.
The whole point here is that if LS heads could flow enough to make good power, there wouldn't be any reason to use VTEC heads with VTEC eliminated.
Old 01-22-2010, 11:16 AM
Shoryuken!
Snoop 95's Avatar
Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95
Originally Posted by Jarrod
fixed.
Yup. And JG-303's work well for a well-rounded street oriented setup.
Snoop 95 is offline
Old 01-22-2010, 11:30 AM
D.Nick's Avatar
So Shawn IS smart? Wow.
D.Nick is offline
Old 01-22-2010, 09:26 PM
johncarlito's Avatar
johncarlito has disabled reputation
your concept make sence ! but the production would be pointless !!!
johncarlito is offline
Old 01-23-2010, 09:07 AM
Red is the new green
NoTorque's Avatar
NoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these partsNoTorque is infamous around these parts
your theory is correct.
to maintain the same amount of air per stroke...(read not flow) is tough...the only way to get around the lift issue/limit of the cap is to lengthen duration of lift but your high rpm performance would suffer with more than 5-10* overlap.......point being made...for the cost/benefit of a custom ground LS cam set, you could buy the vtec head with killer cams...
NoTorque is offline
Old 01-23-2010, 04:36 PM
1rude2l's Avatar
First question i have is for jarrod, i have read you can't use a p8r head on a ls, because of the combustion chambers was made for a 84 mm bore(the b20). I could be wrong or you may have witnessed it done on a ls(81mmbore). If so let me know, been wanting to try it for some odd reason.
The non vtec heads have problems revving that high with very aggressive cams. The rocker arms tend to pop off, remember nothing but tensoin from the cam holding them in. Besides cams that big you loose low end torque, thats why they created vtec and the heads to make the 2 cam profiles work.
1rude2l is offline
mikejones002100
Engine / Exhaust / Drivetrain
19
05-08-2009 03:58 PM
yohomeyg69
07-05-2008 10:07 PM
crxtyper
01-18-2008 10:21 PM
Quick Reply: Vtec head + Vtec lockers = LS head *read
