vtec issue please help.
ok so i did a gsr swap in my Eg hatch and now im having vtec issues. I am getting Cel 21 thats t6he spool valve also knowen as the vtec solenoid. I did all my continuity checks and everything is good. I am running a chipped P06 that i got done by Shawn at Ramey built so i know thats good.i wired everything up to the right spots on the ecu harness.
I am not getting any power to the oil pressure side of the vtec switch wich is good but as soon as i turn the key on im getting 12v to the soleniod is this right? Some one help me out here im running out of ideas
Re: vtec issue please help.
id have to look at it to supply any help, but if I had a dollar for everytime someone made a thread for vtec probs, id be rich. pm me if you want me to come help out after the weather clears
thanks man pmed. by the way i didnt mention that oil pressure is good and i have my knock sensor and o2 sensors deleted on the ecu
If I remember, the ECU sources 12V to the solenoid, and the solenoid is ground referenced, so you shouldn't have anything on that wire until VTEC engages.
still no luck i even rechecked the hook up of the wires to the ecu harness and its fine. I know i have them in the right spots cause the last swap i did i used the same diagram. Any help please im drawing a blank
update: so i hooked my ecu up in my boys car and it did the same thing looks like i have ecu problems. the only thing is that i took his good ecu and vtec solenoid and now i have another problem. now the car drives great no cel till i hit 6500 prms and the same one for the solenoid one comes on. i know the stuff im using from his car is good cause it all worked before i took it out his car and after i put it all back in. damn i just stumpped please help
So you put a known-good ECU in the car, and it works but you get a solenoid CEL. Therefore you have a solenoid (or solenoid wiring) problem. I'm assuming the ECU is doing fault detection when it tries to activate the solenoid, which many/most ECUs do.
Anyway, it sounds like you know where to look.
