VW Golf Issues
VW Golf Issues
Working on a friends 2.0L 2003 VW golf. I recently did a timing belt+water pump on it as the pressed on plastic impeller failed.
She asked me again to look at it so she can get it inspected. As such, it's throwing the following codes;
1.) Primary Circuit Malfunction
2.) Secondary Circuit Malfunction
3.) Coil A Failure
4.) Coil D Failure
5.) Coolant System performance
Currently, the check engine light is on as well as the airbag light. When her water pump impeller, a shop mis-diagnosed it as a coolant temp sensor so they replaced that. From my research, it seems that these cars are very temperamental at having to get to temp quick or they'll throw a code. Should I replace the temp sensor again? I changed the thermostat when I did the water pump as well.
I have no idea why the airbag light is on, but that's preventing it from being able to pass inspection.
Thanks,
Joe
3.) Coil A Failure
4.) Coil D Failure
Thanks,
Joe
Re: VW Golf Issues
3.) Coil A Failure
4.) Coil D Failure
Thanks,
Joe
3.) Coil A Failure
4.) Coil D Failure
Thanks,
Joe
For the coil A and D failure:
Switch them around with the other two coil packs and see if the code goes to those cylinders instead. If it does, then you have a faulty coil.
The airbag light is most likely on for the clock spring in the steering wheel.
Re: VW Golf Issues
Meh - $200 from mexi-zone. It just has the *slightest* of a miss at idle, probably drops like 20 rpm every 4-5 seconds. I'm gonna try and disconnect the battery to clear the ECM and see if the codes pop back up.
Re: VW Golf Issues
I'm gonna throw a Vag-Com scanner on it at lunch so I can offer more details. I was just giving what she provided me.
As far as the airbag light, I just talked to her, she mentioned something in the door? The dealership wanted $500 to replace it.
Re: VW Golf Issues
As promised, here are the codes;
hassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: BEEPBOPBOPBOP Mileage: 81230km/50473miles
Address 01: Engine Labels: 06A-906-032-AVH.lbl
Part No: 06A 906 032 MC
Component: 2.0l R4/2V G 4622
Coding: 00001
Shop #: WSC 00000
VCID: 6BDBC43E19AB3D40E47
[REMOVED VIN] VWZ7Z0B5354478
7 Faults Found:
17772 - Cylinder 4 Ignition Circuit
P1364 - 35-10 - Open Circuit - Intermittent
17763 - Cylinder 1 Ignition Circuit
P1355 - 35-10 - Open Circuit - Intermittent
17769 - Cylinder 3 Ignition Circuit
P1361 - 35-10 - Open Circuit - Intermittent
16840 - EVAP System
P0456 - 35-00 - Very Small Leak Detected
18613 - Performance Malfunction in Cooling System
P2181 - 35-10 - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00000 785 00200
VCID: 336B1C5E511BA580EC7
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0001
Coding: 12344
Shop #: WSC 00000
VCID: 2753F80EC5C3D92040F
1 Fault Found:
00591 - Seat Belt Switch; Driver (E24)
32-00 - Resistance too High
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07232
Shop #: WSC 00000
VCID: 2F63102EED33816088F
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
VCID: F0E15352B08D5E98515
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1J Komfortgerát HLO 0003
Coding: 00064
Shop #: WSC 00000
VCID: 3773284E156349A0D0F
Subsystem 1 - Part No: 1C1959801A
Component: 1J Tőrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: 1J Tőrsteuer.BF KLO 0002
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio 001 0010
Coding: 00401
Shop #: WSC 00000
VCID: DDBF1AE6571FC3F0EA3
2 Faults Found:
00879 - Connection to Speaker Front Right
44-10 - Short Circuit - Intermittent
00881 - Connection to Speaker Rear Right
76
Coding: 00001
Shop #: WSC 00000
7 Faults Found:
16840 - EVAP System
16685 - Cylinder 1
Coding: 0004097
Coding: 12344
Shop #: WSC 00000
1 Fault Found:
Coding: 07232
Shop #: WSC 00000
Coding: 00006
Shop #: WSC 00000
Coding: 00064
Shop #: WSC 00000
1 Fault Found:
37-00 - Faulty
Coding: 00401
Shop #: WSC 00000
2 Faults Found:
