Watery Oil. ...Hot Coolent Temps !!!hELP
Old 03-10-2004, 03:40 PM
Minus Whale
Devin's Avatar
Devin is on a distinguished road
Default Watery Oil. ...Hot Coolent Temps !!!hELP
Recently ...Ive changed my oil about 4 times in the last month due to turbo kit blah blah blah stuff not fitting . So ..the kit is gone ...I had a small oil leak I fied tonight as I drained my oil it was very watery, but looks just as new as the day I put it in. Can anyone explain why this is happening ? My coolent gauge temp seems to also be showing half way up (a little hotter than should be). Any ideas why it just runs so hot ? I would think a thermostat would make it run waaaay hot or waaay cold. Doesnt change when the heat is turned on or off. Any ideas on both these problems guys ?
Devin is offline
Old 03-10-2004, 03:49 PM
go topless.
BillMW's Avatar
BillMW has disabled reputation
Default Re: Watery Oil. ...Hot Coolent Temps !!!hELP
Ooohhh...I'm afraid to tell you it may be a crack in the block or head...hopefully it's a blown head gasket. I'd check that first. Any sweet smell like radiator fluid or white smoke coming from the exhaust? Good luck dude.
BillMW is offline
Old 03-10-2004, 03:59 PM
GotB00stPsi's Avatar
GotB00stPsi is an unknown quantity at this point
what he said
GotB00stPsi is offline
Old 03-10-2004, 04:05 PM
Minus Whale
Devin's Avatar
No smoke or anything ...The coolent is still green ..Its runs like a SOHC should I guess. Still gets great gas miliage etc ...Could it running Half way up the temp gauge for along time break down the vecosity of the oil ?? Or am i just a retard and hoping ?
Devin is offline
Old 03-10-2004, 04:09 PM
DURRRRRRRRRRRRRRRRRR
The Wok's Avatar
Pull plugs, see if any of them are covered in white powder. If the oil is kind of misty/milky and the car smokes at all, it's probably the head gasket. Those are all good indicators, at least on MR2s. I'd imagine it's the same.
The Wok is offline
go topless.
BillMW's Avatar
What weight oil?
BillMW is offline
Old 03-10-2004, 04:24 PM
been around awhile.
zappas's Avatar
zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas
do a leakdown test.
zappas is offline
Old 03-10-2004, 05:00 PM
It's Duck Season
JBub's Avatar
JBub JBub JBub JBub JBub JBub JBub JBub JBub JBub JBub
Originally Posted by zappas
do a leakdown test.
compression too
JBub is offline
Old 03-10-2004, 06:00 PM
Dont Be Scared Homie
Neo Xian Wu's Avatar
hopefully it's not a cracked head. that happend to me when i overheated. cost me 400 bucks. had milky like spots in the oil and such. i'd advise you not to drive it too much, cuz if you're getting coolant in your oil, it's gonna wear out your bearings. and if that happens, you'll be putting a new motor in like me
Neo Xian Wu is offline
Old 03-10-2004, 07:03 PM
Minus Whale
Devin's Avatar
The oil looks as if its brand new ...I really dont know ...Plus are new also and they look fine last time checked. Im gonna be hopeful and try my thermostat for my heating problem and as for the oil I guess time will tell. I hope not soon though I gotta get to work some how .
Devin is offline
Quick Reply: Watery Oil. ...Hot Coolent Temps !!!hELP
