Weird sound coming from wheels
Old 12-09-2009, 12:16 PM
backtoarms's Avatar
backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms
Default Weird sound coming from wheels
After I installed some drilled/slotted rotors and new pads I have a weird sound coming from that area. Kinda like the pads are catching on the slots. But they're not. Sound like a helicopter but not nearly as loud. Any ideas?
backtoarms is offline
Old 12-09-2009, 12:20 PM
MARK IT ZERO
ufctapout's Avatar
Default Re: Weird sound coming from wheels
Blast them with piss.
ufctapout is offline
Old 12-09-2009, 12:23 PM
backtoarms's Avatar
Yeahhh... no.
Old 12-09-2009, 01:27 PM
peaches
b16EFsedan's Avatar
bad calipers.....cheap parts...... is the rotor all fucked up now??? do they still work or do you feel the problem
b16EFsedan is offline
Old 12-09-2009, 02:28 PM
Probably just thick pads that don't have as much clearance as worn pads when they retract. It's not unusual to have rotors that aren't totally flat, but cheap rotors can be particularly bad in that department.
Old 12-09-2009, 06:35 PM
civickid03's Avatar
civickid03 has disabled reputation
check the metal shims that go on the caliper bracket (if you have them installed) to make sure they arent making contact with the rotor
civickid03 is offline
Old 12-10-2009, 05:58 AM
csb89's Avatar
csb89 has disabled reputation
my crx made a simillar sound from the front driver side i would kick it hard as fuck n it would stop for a lil bit
csb89 is offline
Old 12-10-2009, 06:00 AM
Zerofucksgiven
Cyanide Jello's Avatar
lmfao
Jack the car up, pull the wheel off, turn the rotor, listen... Correct problem...
Cyanide Jello is offline
Old 12-10-2009, 09:19 AM
backtoarms's Avatar
I think it was just the new pads being so thick, they wouldn't retract all the way so they were tapping the slots. Because after driving and braking a few good hard times, it's stopped. Thanks peeps.
sbdunkz757
11-28-2009 07:13 AM
hondazccivic
06-02-2005 11:01 AM
H22-T
02-07-2005 05:29 PM
kyle
12-20-2002 04:52 PM
Quick Reply: Weird sound coming from wheels
