what can i do about this..........
Old 12-13-2008, 09:30 PM
slowrex's Avatar
slowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these partsslowrex is infamous around these parts
Default what can i do about this..........
my da teg is leaking water down to where the spare tire is what can i do to prevent that from happening please ket me know i need some advice on this problem.
slowrex is offline
Old 12-14-2008, 05:20 AM
tatmonster's Avatar
Default Re: what can i do about this..........
It can be your tail lights leaking. Or the sunroof drains(if you have one).
tatmonster is offline
Old 12-14-2008, 05:21 AM
Chicken Little
ruger988's Avatar
Damn man, you got some shitty luck with water in this car huh? Where's it coming from (or is that what you're asking?)
ruger988 is offline
Old 12-14-2008, 08:08 AM
slowrex's Avatar
ya i know i got some shity luck with this but i like the car so i am teying to fix every thing i dont belive its the sun roon might be coming from te tail lights n the back idk might have to get some kinda seallent stuff to put around the tail lights
slowrex is offline
Old 12-14-2008, 08:23 AM
Dickbutt #peentip
Kris.Is.Foamin's Avatar
Tail lights leak on every old honda.
New gaskets should do the trick.
Kris.Is.Foamin is offline
Old 12-14-2008, 10:17 AM
Shooting 63's
idriveahonda's Avatar
If you really want to find out what the problem is.
1. Get a friend.
2. Put the backseats down, have a flashlight, and chillin the trunk.
3. Get a hose.
4. Put on the highest pressure, and spray the entire car.
5. Look for water and entry points.
And you should find your problem.
idriveahonda is offline
Old 12-14-2008, 10:35 AM
slowrex's Avatar
where can i get the gasket at for that
slowrex is offline
Old 12-14-2008, 10:54 AM
Sup, ladies?
Lestar's Avatar
Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar Lestar
Use some silicone. Mine does it too, but I'm just too lazy to fix it. I have a leak up front too.
Lestar is offline
Old 12-14-2008, 11:37 AM
slowrex's Avatar
so did that help the problem by using that
slowrex is offline
