what fpr do i need to use with hondata s300
![sweethatch1866 has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
thanks for the advice! im shooting for 550 to 650 whp. i havent cut any corners building my swap and it shouldnt have any problem producing those number. for those of you interested in my build here is what i have so far. sleeved b20 block, eagle crand, scat rods, wiesco 9:1 pistons 87mm bore, type r oil pump, gsr girdle conversion, moroso 6 quart oil pan, power force damper, competition clutch and flywheel, p&p b16 head with springs ect, blox type b cams, cam gears, skunk2 intake manifold, 75mm throttle body, rc1000cc injectors, greedy timing belt, full msd kit with two step, oil cooler, 3 inch exhaust, ls tranny with lsd and carbon syncros, and of course the nessary mounts ect. ect.. the turbo kit is a full t4 kit i pieced together. tubular manifold, t4 60-1.15 turbo twin scroll, 500hp intercooler, 3 inch piping, greedy type s bov, 50mm wastegate, then the s300 ect. im anxious to see how she runs
![good_fellaz_76 has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
X2...literally. (no pun intended)
For 550 wheel, you'll be fine with the single 255 Walbro you listed. For that 650 goal, run the Full Blown kit with dual Walbro's, or run an inline Bosch 044 with that single Walbro you already have. Your 1000 cc's will support the 650 as long as your fuel system is up to snuff, hence the dual pumps.
If that was my setup, I'd swap out the scat rods for Eagle H-beams, cop a Presicion 600 hp FMIC & swap the Blox cams for Skunk2 Tuner 1's. But you do have an awesome setup there.
![Thumbs Up](https://www.vadriven.com/forums/images/smilies/thup.gif)
yeah im not going to be disapointed if it doesnt push 650hp because im gonna keep blowing clutches so i think ill stick with the single fuel pump and see what happens if it doesnt put out what i want then ill switch it out. and yeah the bore is 87mm!!!! its rated to hold 40psi so 25psi should be fine. as far as the rod, scat says they are 650hp compatible and i had them mechined to accept larger bolts. we'll see i guess
Scat makes good parts, don't worry. People like to leg hump Eagle stuff (and they make great stuff) but they aren't the only people out there for high power Honda parts.
