Whats the Difference between 4WD and AWD?
The different is AWD provide power to the wheels that slip for better traction. 4WD has all 4 wheels powered at the same time, equal to all tires no matter the condition. AWD if one tire slips it shifts more power to the wheel that is not slipping.
Close,
AWD = AWD setups are full time systems for year-round driving. Most use a viscous fluid coupling (Similaro to a torque converter) center differential instead of a transfer case to route drive torque to all four wheels. This allows the front and rear wheels to turn at slightly different speeds when turning on dry pavement. Because of the way it works (AWD) is a slightly degraded version of 4WD because all 4 wheels can NOT be locked at any given time, generally the most that can is 3 wheels in some cases only 2 wheels (1 front 1 rear)
4WD = The vehicle is constantly providing power to all four wheels via a mechanical coupling (i.e. locked), usually with power being shifted between the front and rear axles as needed. This provides maximum traction in both dry and slippery driving conditions but is very poor for on-road driving.
i think the description of 4wd and AWD must be a mainly stateside thing, in japan they refer to all of what we call "awd" cars to be 4wd..
basically 4wd/awd can be the same thing.. and there arenty maby oem cars that come equipped with mechanical lockers.. maybe land rovers?
A wannabe pro
![Anti-rice71 has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
i have argued this for a long time, and from my worthless knowledge that means nothing i have come up with this. AWD means that any of the wheels can be power driven when needed most of the time AWD is full time but does not mean that all the wheels are driving all the time only when they are needed. Now 4wd does not mean that all wheels drive either at the same time, 4wd has to be locked in there is a seperat total drive train for each set of wheels that can be bypassed which is not the case for AWD. when u have a truck in 4wd the front wheels are not driving as fast as the rear yet they are only there to give u pulling power that is why it is not good to drive on dry pact surfaces with 4wd. now days AWD is computerized also so that is a big difference and the driver has no control.
A wannabe pro
most 4wd vehicles only run 2 wheels at a time, for example front left and right rear, watch a toca make a run through the mud u will notice it.
Boosted F2B
![99EJ6T is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
awd= all wheel drive/driving, power is the same to all wheels unless one slips then power is transfered to any of the other tires
4wd= 4 wheel driving, power is not the same to all wheels and it doesn't transfer front to rear or vise versa just left to right
Quit your Bitchin...
![diggum has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
Originally Posted by vmspionage
4WD just doesn't sound right for a car. When you see 4WD you think of off-roading and such. AWD sounds like something for safety in the rain. FWD means gas milage and RWD means real performance.
Class dismissed.
![Stick Out Tongue](https://www.vadriven.com/forums/images/smilies/tongue.gif)
![Stupid](https://www.vadriven.com/forums/images/smilies/stupid.gif)
Originally Posted by Moriar
beach, my 01 highlander does not come with a shifter to change from 4wd to 2wd or nething its jus all time 4wheel
