where is this moisture coming from???
![kgard is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
Everytime it rains i end up with water in my hatch. I have to take a shop vac and get it out. None of the carpet is wet nor is the carpet in the hatch area wet. But there is water under the spare tire and the sound deadening pad. Someone please help me where this is coming from. Also, I'm looking at my sunroof and even though it opens and closes, when in the closed position the back part of the sunroof has about a half inch gap from being closed completely. Someone please help.
Lost Cat Magnet
![drifterJERRY is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
check the rear glass seal around the lower corners.
also, the seal around the taillights have a tendancy to leak, its only a little foam gasket. sometimes they rip = leak.
9 grand safely...
![Inprov is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
I never got water in the back of my '91 hatch but the sunroof on mine looked fine, but every once in a while when it was raining all night I would get in it the next morning, take off, and as soon as I hit the brakes, SOAKNFRIGGINWET!!! Not cool...
![00CivicGirl is an unknown quantity at this point](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
check your sunroof drain. most run behind the panels in the hatch in the trunk..our integra's had come loose and caused water to accumulate in the spare tire area
卐 Walnuts
![EEK](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![EEK](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
its your real seals ethier around the trunk lid or one of the tail lamps, check them all, its a common problem in hatchs, and also a good sign that your hatch was in an accident before
