Why does my clutch in 91 civic have no pressure??
Re: Why does my clutch in 91 civic have no pressure??
yeah its new throw out bearing... is it possiable for the clutch cable to stretched or maybe the clutch or pressure plate is defective
I suppose it's possible. It's not very likely though. Again, did you break the clutch in properly?
its only been in for two days. and as soon as i started putting clutch cable on i could tell then something was right cause it had so much slack in it. i had to tighten it all way down for it have any pressure
well the clutch and the flywheel being wrong could be a potential problem but it doesnt explain why your not getting pressure, i would say it has something to do with your Clutch master cylinder or the slave stoner but sounds to me that either your master cylinder is bad or the lines not getting properly bled out
HINT #1: It's a cable clutch, because it's a 1991 transmission. It says so right in the thread.
HINT #2: It's really, really, really difficult to bleed a clutch cable.
Stea1thy
Engine / Exhaust / Drivetrain
09-25-2009 09:14 AM
dirty1thirdee
04-04-2009 05:51 AM
