Y8 swap into '94 del Sol. ECU not getting power
I <3 Hikki Chan!
![ProbeGT-ZE](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![ProbeGT-ZE](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Okay guys here's the situation. I removed the B7 from my del Sol and replaced it with a new Y8. I switched the intake manifold (Skunk2) and I have the B7 distributor on it as well. I'm obviously using the B7 harness, everything is connected (I just did a Z6 swap on my Dad's hatch) where it's supposed to be. Mind you this car ran just fine before I swapped the motor. I took the harness off and re-wrapped a few things but nothing too serious.
Now the swap is installed and everything's connected but I've got no power to the ECU. The CEL doesn't even turn on when I turn the key to "on" no pump priming or anything. I found this strange as it worked just fine and I drove it into the spot that it's in on the driveway now. I've double checked my grounds and all are tight and where they're supposed to be. If I can't figure it out I'm just going to find another harness to replace this one with, preferably a vtec one.
Any input would be greatly appreciated guys. Thanks in advance.
check relays/fuses/battery connections?
check to make sure no wires came out of a connector after u wrapped everything?
are you sure the b7 and y8 harness is compatible? its been a while since ive messed with d series...but del sol's were obd1, not obd2, right?
I <3 Hikki Chan!
del Sol's came OBD1 and OBD2 but the harness on this car is OBD1, the Y8s harness isn't used as it's for an EK chassis.
No wires came out of any of the connectors, I think it might be the "main relay" I keep hearing about, not sure what it controls. I thought if it's the main relay nothing works at all, but I could be wrong about that.
certified asshole
![crasy87rexsi](https://www.vadriven.com/forums/images/reputation/reputation_neg.gif)
![crasy87rexsi](https://www.vadriven.com/forums/images/reputation/reputation_highneg.gif)
Recheck all your grounds, clean them with sand paper or if you have air tools use a scotch pad(it works wonders), mainly check and recheck the ground on the thermostat housing as this is the ground for the ecu. Check continuity of the ecu grounds that will tell you everything and make sure your getting power to both 12v ecu pins. Yes, the moisture can affect electrical componets, it will start to corrode connections, causing bad connections. If you was in the 540 area I would assist.
Need any more help PM me.
![UrGrlGveMeDkBrn](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![UrGrlGveMeDkBrn](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
just had same problem it all turned out to be after market alarm system. If i were u i would check the main relay its a gray box with a connector going to it, it is right near the fuse box try that
90singleslam
09-06-2007 03:13 PM
20four7
08-20-2003 10:17 AM
