clutch
Old 11-03-2004, 07:55 AM
i have a 1G now tho
secgendsm's Avatar
secgendsm is an unknown quantity at this point
Default clutch
anyone know how to do a clutch? mine is starting to slip so i need to get on that. also if u know of any good clutch deals lemme know. thanks
secgendsm is offline
Old 11-03-2004, 08:35 AM
<3FreshieFresh<3
ZeRo_C0oL's Avatar
ZeRo_C0oL is an unknown quantity at this point
Default Re: clutch
I'm trying to find somewhere that I can trust to work on my car.
ZeRo_C0oL is offline
Old 11-03-2004, 08:37 AM
To the future...
Hart-n-Sol's Avatar
Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol Hart-n-Sol
Default Re: clutch
to far away for me but good luck.
Hart-n-Sol is offline
Old 11-03-2004, 11:25 AM
gonzoe00's Avatar
gonzoe00 can only hope to improve
Default Re: clutch
http://www.dragva.com/forums/showthread.php?t=71497
This thread should help the non do it your selfers.
gonzoe00 is offline
Old 11-03-2004, 11:54 AM
Ivy Tadita
cootees's Avatar
cootees will become famous soon enoughcootees will become famous soon enough
Default Re: clutch
They are not hard at all on 4g63's. btw, vfaq is your friend. Here it is for a 1st gen. Unless you have a 1.8 it'll be he same for the most part on both awd and fwd. http://vfaq.com/mods/clutch-1G.html
cootees is offline
Old 11-03-2004, 11:56 AM
Ivy Tadita
cootees's Avatar
Default Re: clutch
The sports car clinic. You can trust them.. but you'll pay out your ass.
cootees is offline
Old 11-03-2004, 12:32 PM
<3FreshieFresh<3
ZeRo_C0oL's Avatar
Default Re: clutch
I think I'd take my car to Martin's before I'd take it to the Sports Car Clinic. I talked to Martin, and he said the labor would be approximately $400 for a clutch install on my 1.8T. I was kind of disgusted when I started calling around to find out local prices, because the shop I'm buying my clutch from in Texas does clutch installs for $200-250.. Would almost be worth driving there to have the clutch installed.
Old 11-03-2004, 01:44 PM
i have a 1G now tho
secgendsm's Avatar
Default Re: clutch
i mean i want to try to do it myself but...i dont trust myself to do it alone...so i was looking for some help...and it is a 1g awd
Old 11-03-2004, 02:04 PM
elementalwindx's Avatar
elementalwindx has disabled reputation
Default Re: clutch
1g's are childs play. i could get yours out and in within 5 hours max.
mine on the other hand 24 hours. stupid engine mounts and needing to support my own engine.
All you do for your 1g is drain the tranny, take out 2 mounts, a few sensors, the pass side strut (if you want the extra room, or you just push it out enough to move the axle) and unbolt the tranny. The only thing I hate about taking out a tranny is getting it back on, and taking off the axle because you need some kind of huge socket and wratchet to remove the huge nut that holds your discs on.
elementalwindx is offline
Old 11-03-2004, 05:27 PM
The Pro to call.
HatefulMechanic's Avatar
Default Re: clutch
uh, no.
pm'd. you signed off of aim when i got home.
HatefulMechanic is offline
Quick Reply: clutch
