Good place to get meth...
Re: Good place to get meth...
Originally Posted by LLama
ahahaha when i first read the thread title.... i thought "what the fuck, he cant do that"
Originally Posted by BSeriesTurbo
Does anyone know of places in roanoke/salem area that sell 100% methanol?
Thanx in advance.
Thanx in advance.
I assume you are referring to meth/alc/water injection..
Thanx in advance.
Thanx in advance.
actually you can make your own with some hydrogen, carbon monoxide and a some copper to act as cataylist. but i don't think you want to go into the business of making chemicals in your house. maybe a better question is how much do you need?
Some other info to think about is the drawback of methanol as a fuel is its corrosivity to some metals, including aluminium. Methanol, (a weak acid) attacks the oxide coating that normally protects the aluminium from corrosion. The resulting methoxide salts are soluble in methanol, so the corrosion continues until the metal is eaten away.
wub wub wub wub
hahaha.. I thought I pee'd myself a little when I read the title. I was going to hook you up with this dumbass that I used to work. I'm sure he's cracked out on something right now and would know where to get meth
Originally Posted by 20psi 240sx
i produce more then enough. i just haven't found a way to trap it when it exits my ass.
Get a tub full of hot water in your bathtub
Sit in the water
Take an empty glass jar with a tight-fitting lid
Take the lid off, and put the jar under the water so it fills with water
Invert the jar so the opening is pointing down
Hold the jar over your junk, and when you fart, the gas bubbles go into the jar, and displace the water
When you are done, put the lid on the jar under the water, trapping the gas and water
Next time you get in the tub, put the jar under water with the lid pointing down, and take the lid off
Continue filling until all water is gone from the jar
When you are done, you will have a jar that is 100% fart. Do with it as you please. I like to take a couple dollar bills and put it in the jar before I start, then, when I'm done, take the jar to the mall and set it down in the middle of the mall, and then walk away. Someone will come by and open the jar to get the dollars out, and will be greeted with a glorious aroma. But, that's just one use. The possibilities are endless...
