Need some DSM parts..
Old 12-08-2004, 05:23 AM
  #21
Ivy Tadita
cootees's Avatar
cootees will become famous soon enoughcootees will become famous soon enough
Default Re: Need some DSM parts..
Do you need some injectors too?
cootees is offline
Old 12-08-2004, 11:17 AM
  #22
GaRn's Avatar
nah goin with the good ol' shitty FMU(for now atleast..)
GaRn is offline
Old 12-08-2004, 11:46 AM
  #23
I <3 2JZ
Spooln4's Avatar
Spooln4 has a reputation beyond reputeSpooln4 has a reputation beyond reputeSpooln4 has a reputation beyond reputeSpooln4 has a reputation beyond reputeSpooln4 has a reputation beyond reputeSpooln4 has a reputation beyond reputeSpooln4 has a reputation beyond reputeSpooln4 has a reputation beyond repute
I've got some parts laying around:
1g 02 housing
1g bov with adapter
2g bov
450cc stock injectors
The 14b turbos are internally gated and it would be hard to run 5psi off of it considering when my old 14b was fully ported and had a 34mm flapper I could only get it to a lowest of 8psi and it still crept to 10psi at the end of gears. You might be able to modify the Wastegate arm so you can adjust it tighter, or just go external. External is so much smoother and solid. I'll never buy an internally gated turbo again.
Also if you do end up using the 1gbov. Make sure you re-route it back into your intake track. When I vented this bov it made the car buck and it was jerky on and off throttle. The 1gbov should be more than enough for your setup, hell alot of dsmers use them 20psi+ after modding the vacumm ports.
Spooln4 is offline
Old 12-08-2004, 12:40 PM
  #24
No Turbo & No Talon
Turbo Talon's Avatar
Turbo Talon has disabled reputation
i have a dsm 1g bov pipe - no bov
Turbo Talon is offline
Old 12-08-2004, 12:52 PM
  #25
GaRn's Avatar
1g 02 housing
1g bov with adapter
2g bov
yup i was thinkin i could bend the arm slightly to shorten it, then it would bleed off a little early possibly, but o well.. now i am going with a t3, hopefully find one gated around 7 psi and work with it a little to get it down.. unfortunately the manifold i want isn't flanged for an external, but i could get it modified.. thats more $$ tho
on the lude the MAP sensor is built into the throttle body so i don't have to worry about the issue with re-routing, which could be good or bad cuz now it will be louder..
GaRn is offline
Old 12-09-2004, 08:54 AM
  #26
I <3 2JZ
Spooln4's Avatar
I was just refering to the 1gbov, and the way it acts when vented. I am venting a HKS SSQV with the stock MAS sensor in the intake track and it doesn't buck or flip out nearly as bad as the 1g did. I think its because the 1g is slower reacting between vacumm and pressure , this is just from my experience.
Spooln4 is offline
Old 12-09-2004, 01:02 PM
  #27
GaRn's Avatar
oh i gotcha, didn't know that, thanks for the heads up though
GaRn is offline
Old 12-12-2004, 03:57 PM
  #28
Master of my domain
nukefission's Avatar
nukefission is an unknown quantity at this point
I have a good condition 14B, oil & water feed lines/bango bolts included. $150.
nukefission is offline
