Wow it actually works!
![Turblowedneon is on a distinguished road](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
Well I hooked up my SAFC II a day ago and it works fine the only thing i am lacking is the MSD tach driver for the RPM it is going to be here tommorow. MY question is.........Is there anyone on here that knows how to tune these, I know that I cannot Richen my fuel until I get a Return line system and a fuel pressure regulator, and injectors, But who can tune it and get it close to normal settings So that i am running stoich or a little rich at higher rpms. I dont want to run it somewhat lean untill I can aford an in car wideband. I hooked the TPS wire to the map like the directions from SRTFORUMS said to do so that you can use the boost as a refernece rather than throttle position so that your safc knows when to use high and low settings.
![Cosmo](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Cosmo](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Here's a good site for infor on tuning (it uses the original SAFC, but the concept is the same):
http://www.roadraceengineering.com/newafc.htm
PtOwN VtEc
12-06-2007 01:21 AM
