Ls meshes with great tires for trade for si's or blades
![experthondakid has disabled reputation](https://www.vadriven.com/forums/images/reputation/reputation_off.gif)
Means of contact: pm or text
Price: $300 or trade for si's or blades
Wheel Brand/Model: Acura Ls meshes
Diameter:
Lug Pattern:4x100
Width:
Offset:
PCD:
Tire size:15
Tire brand:kumho
Tire model:Estas
Tread life left:85 percent
Pictures:
Text for pictures
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
Diameter:
Lug Pattern:4x100
Width:
Offset:
PCD:
Tire size:15
Tire brand:kumho
Tire model:Estas
Pictures:
Text for pictures
![experthondakid is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
Go cry to momma
![Nunyabidness](https://www.vadriven.com/forums/images/reputation/reputation_pos.gif)
![Nunyabidness](https://www.vadriven.com/forums/images/reputation/reputation_highpos.gif)
Negative, ghost rider. Sufficient info is required, as are pics of each wheel. PM me when you get that info and your pics. Do not make another thread, I'll reopen this one for you to edit your OP.
![Nunyabidness is offline](https://www.vadriven.com/forums/images/statusicon/user_offline.gif)
da90
Wheels / Tires
09-26-2010 03:36 PM
